OLEDB Provider missing
Hello
I am having an issue only on my client or deployment machine where my Data Connection is not working.
I believe it is something to do with the MDAC  but I am not sure how to fix that.  I have removed the MDAC and reinstalled it.
Every time I try to save something in the client machine I get the error attached but always works fine in my development machine.
I would appreciate any help if anyone had similar issues.
Thank you
JCollado
(3,214 Views)
How are you specifying the connection (ie udl) did you test the connection on the client outside of labview?
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(3,209 Views)
It is UDL
I tested it only on the development machine.
I did test the exe on the development machine outside of labview.
JCollado
(3,199 Views)
What I would do is
1.  Get the connection on the deployed machine udl working with thest connection (on the udl 1st tab I think)
2.  Validate the path on the deployed machine to the udl is correct, maybe use a temporary indicator.
Most likely the udl is invalid (missing provider??) or the path to the udl is invalid.
Paul Falkenstein
(3,193 Views)
