OPC Interface Not registered error
I am trying to get connected to my OPCLabVIEW server with a remote client (ni explorer), but I keep getting a response when I try to connect that states "Interface not registered Status Code : 0x80040155". Also I am trying to use a second party OPC client but it can see the tags file and pull the data from the server, but when I try to establish the server into a Push mode (meaning I would now like it to push data to my client when it sees a data change) the server returns with an error that states there is not enough memory to perform this task. Any help is GREATLY appreciated.
(5,198 Views)
The best way to re-register your OPC server is to uninstall and re-install the software that installed it, LabVIEW in your case from the sounds of it. That should take care of registering everything correctly.
JR A.
(5,198 Views)
