OPC SErver/Modbus/ C++ Dll
Hi
I am currently facing this problem and dont knw wht to go for???
Laptop 1(Labview GUI Developed)
Laptop2 (Same C++ GUI but connected to Hardware)(Only .exe file is available and no C++ code)
 I need to interface or connect  Laptop1 with Laptop2 so that I can also get same data in Labview. In simple words how should I import data from Laptop2 to Laptop1.
(3,241 Views)
Accepted by topic author arrowminds
Hi Arrowminds,
How does the C++ code export the data?  If we know this and it is compatible with LabVIEW then we can try and get it in.  However because the C++ code is an executable if it is not designed to export data that LabVIEW can recieve then we cannot alter this to add the functionality and unfortunately there wont be a way to do this without the source code.
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
(3,210 Views)
HI james
I have understand the fact that its not possible to import data to Labview without publishing of C++ data.
(3,200 Views)
