OPC Server for Labview/PXI-RT
Hi all,
can i access Labview on a PC/WinXP or a PXI/RT System  with a OPC-Client (eg.:WinCC/Siemens) like a Compact Fieldpoint over the NI OPC Server (NationalInstruments.OPCFieldPoint). Exist a OPC-Server for Labview/PC/PXI?
Achim
(3,352 Views)
Here you can find information concerning this issus:
Hope this helps!
(3,339 Views)
Hi
thanks for your answer. This works very well. I can access this mit WinCC (Siemens) on a local VariableEngine but not on a remote PC. The Server Explorer from NI works on both. I think this is a problem of access rights. Any suggestions?
Achim
(3,321 Views)
