OPC UA Certificate Store Failure on cDAQ-9133 Linux RT
I am seeing the following error when I try to initialize the OPCUA server on my cDAQ.
Error -356705 occurred at NI OPC UA Utility.lvlib:Create Certificate.vi
Possible reason(s):
OPC UA Toolkit: Failed to create certificate store because access is denied.
I understand that the OPCUA Create Certificate attempts to create files in the following directory:
/files/var/local/natinst/certstore/opcua/Default OPC UA.der
/files/var/local/natinst/certstore/opcua/Default OPC UA.pem
For some reason the creation of these file is denied or is inhibited.
(2,968 Views)
Hi viScience,
I think this problem may be caused by the write permission is not opened for the folder of opcua.
Thanks!
(2,943 Views)
I agree with you, it is probably a file permission issue but I have no idea why.  I have 2 other cDAQ-9133 chassis and they are working properly.
(2,937 Views)
I wanted to add that on the cDAQ that is not working the cert. directory is seen as
There is no opcua subdirectory present.
(2,932 Views)
Hi viScience,
If you correctly install the OPC UA Toolkits, there should be the opcua folder in the path /files/var/local/natinst/certstore. I would suggest that you formatting the cDAQ and test again.
Thanks!
(2,922 Views)
