OPC UA Client failed to connect to Server
I am performing a very simple OPC UA Sever-Client Communication (Same as the one in the Examples).
The communication should be secure (using the generated certification).
Actually I generated Two Certificates (For the client and the server) and added them to configuration.
My Problem is that I cannot the client to the server. I am having this error. (Although the file exists)Capture.PNG
Can anyone please help me which certificates to use for the configuration because the "Create Certificate.vi" generate two files (*.der & *.pem).
Thank you in advance.
(3,886 Views)
Accepted by topic author HichemB
I just used the public keys (*.der) and ignored the other generated private keys.
(3,864 Views)
