OPC UA Connect.vi very slow
I have an issue with the connection to a local TwinCAT OPC UA Server.
I am running a machine, in which two industrial computers are 100% identical.
My problem is that using the NI OPCUA (2017) Client.lvlib:Connect.vi to connect to a local OPC UA server, in one computer it takes about 1 second and in the other one 10 seconds (e.g. in screenshots).
Both the computers run on Windows 7 and are using LabVIEW 2017.
Did anyone have a similiar issue and might know where it comes from?
Best regards
(2,109 Views)
after upgrading to Windows 10 the connection issue was gone.
This thread can be closed.
Thank you,
David
(1,984 Views)
Thanks for sharing the solution to the problem.
(1,980 Views)
You can also mark your own post as a solution.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(1,975 Views)
