04-17-2020 11:36 AM
I'd like to read and write cluster data to a PLC. I have a cluster containing one Double and one UInt16 and I try to read it with "NI OPC UA Client.lvlib:Read.vi" with the variant instance selected. To write I'm using "NI OPC UA Client.lvlib:Write.vi" with the variant instance selected.
Read returns status "Bad_TypeMismatch", Write returns status 2155020288.
Reading the cluster elements individually works fine. Is there a way to read the complete cluster at once or can Labview only read individual elements?
Write returns always state 2155020288, also when accessing individual cluster elements.
When I want to write a Int32 scalar write returns the same error (Int32 instance selected). Writing the same scalar with Labview 2015 "OPC UA write" works fine.
Do I have to setup the server in a different way?
02-16-2021 04:30 AM
has this been solved?
Thomas
