OPC Write
I'm using LabVIEW 8.6 with DSC module. I build the OPC server link to my Siemens S7-200 PLC, by using the I/O server build a OPC client to interface.
I create 2 tag for testing my application :-
1. Direct read input from the PLC
2. Direct write to the PLC output
For the input I success get the result from PLC input and updated to my front panel.
For the output, I create a control at front panel and link to the variable, but the control result did't respond to my output.
* no error occur when running
* link interface is correct checking by using 'NI Distributed System Manager' at tool menu
* I try using "PC Access OPC server" & "KEPServerEX (KEPware) OPC Server" but get same result can't write
(5,182 Views)
Did you setup the second item to have read/write access?? Sometimes the default is to read only.
(5,156 Views)
Yes, already choose to the read/write type.
(5,094 Views)
Accepted by topic author Keele
It's event-base triggering, using event to trigger it.
(4,887 Views)
what does event base triggering mean? And how to do it?
(4,416 Views)
Are you using UA or Clasic OPC ?
(4,284 Views)
