OPC and error code 1950679030
Communication between LabView and an OPC-server only works when I run the "Distributed System Manager" at the same time. Otherwise i get the error code 1950679030.  Any hints?
/Mats
(3,451 Views)
Do you get this error at all times? Or, does the shared variable read correctly the first few times and then you get the error? Posting a snapshot of your code would be helpful.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,446 Views)
The code is just for testing so far. 2 signals connected to gauges.
I get the error everytime.
If I start  the "Distributed System Manager" from the tools menu it works OK, no errors.
The OPC-server seems to work OK. I've checked this with Matrikon OPC-Explorer.
(3,441 Views)
Have a look at this:
http://forums.ni.com/ni/board/message?board.id=170&message.id=267124&requireLogin=False
Maybe the error is associated with respect to the timing of the reads? Try to put a wait in your loop to see if you get the error?
Adnan Zafar
(3,438 Views)
It doesn't work even when I singel-run so I don't think it's a timing problem.
(3,422 Views)
