OPC read - node syntax
Im working on simple application that reads one value from PLC via OPC protocol, but im unable to setup "node path" correctly.
1) im able to see PLC and the values at OPC expert software
2) connection between Labview and PLC is successful (browse results are showing something)
3) but i got error reading values because my "node path" is wrong (i used path from OPC expert software)
Could you help me with correct syntax for my "node path"?
Im using labview2016.
Thanks a lot
Message 1 of 1
(662 Views)
