OPC shared variable cannot be read on RT target
I created a Shared Variable on My Computer which is bound to an OPC server. I then created a VI on a RT target which reads the value of that shared variable. But although I run the VI for about 20 seconds, the value is never read. If I run the same VI on My Computer, the value is read properly.
If I create a shared variable not bound to the OPC server and create a VI that links the OPC server to that shared variable, I can also read it from the RT target.
Do you have any suggestions?
(3,132 Views)
Hello, your first method should work, do you add an OPC Client to the project first? ( My computer >> New >> I/O Server ) before adding the bound variables?
(3,117 Views)
Yes, I am doing that. However, when I attempt to run the VI, I get this error code:
 -1950679027
Shared Variable in opconrt.vi<APPEND>
This error or warning occurred while reading the following Shared Variable:
\\My Computer\OPCLibrary\Ch0V0Set
\\192.168.1.3\OPCLibrary\Ch0V0Set
I read that it corresponds to "NI-PSP has not connected to the server yet", but what does that mean? I assume it's referring to the Shared Variable Engine or Scan Engine, but I thought those are launched automatically as the RT target is booted, and so it should have worked even in that case.
Thanks for your time,
Pablo Mosteiro
(3,107 Views)
