Showing results forย
Search instead forย
Did you mean:ย
OPC
Hello
I am having a problem to stablish a connection between the OPC NI instruments and my LabView program.
I have the OPC server running on my computer  and when I try to create the Data Binding via a Data Socket connection for a specific element on my front pannel to communicate with a Tag in my OPC server, LabView begins to search the "OPC Registry" forever so I cannot access my Tags...
i  would appreciate any help
Thanks ๐Ÿ™‚
(2,876 Views)
There are specific DCOM settings necessary in order to call OPC tags.
One of them is available in this URL
http://www.opcactivex.com/Support/Tutorials/DCOM_Tutorial_-_Configuring_th/dcom_tutorial_-_configuri...
You could also use any search engine for OPC DCOM Settings.
Hope this helps.
(2,855 Views)
