OPC
i created a OPC Server Client communication with a PLC.
If I use the OPC Quick Client I can see the variable and the changing values. But if I use the bound Variable in my Labview vi, the values are not shown.
Dut to the QuickClient works fine I have no idea where I have to look for the solution. So maybe somone can gibve me a clue which settings I can check to find a solution.
LV V 2022 Q3 (32-bit)
Real-Time Module
DSC installed
(1,134 Views)
I start to use Labview. Could you explain or give some guidelines on configuring this OPC server?
Edwin
(944 Views)
