OSCILLOSCOPE PICTURE IN LABVIEW
HELLO ,
I am trying to make the acquisition and signal processing from an oscilloscope ,
and I 'd like to know if I could have the picture goes on the oscilloscope on labview
" without going through the function graph " the exact image on my oscillocope : see enclosed room.
Message 1 of 12
(9,629 Views)
I believe some of the scopes have web interface, so you can get a picture in browser.
To put it into LV panel, you can use .Net or ActiveX container and Navigate2 address.
This works if webcam is not a solution 😃
Message 2 of 12
(9,619 Views)
There should be a Hardcopy command for the oscilloscope you can use to get the image and save it.  Here is an example of how I did it: http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/Screen-capture-of-Tektronix-MSO4104B-using-La...
Message 3 of 12
(9,607 Views)
hello
your solution is interesting , but being beginner somehow has access
all the functions included can you help me
thank you
Message 4 of 12
(9,570 Views)
First of all, how are you communicating with the oscilloscope?  What model is the oscilloscope (I can tell it is Tektronix at least)?  Are you using the LabVIEW drivers?
Message 5 of 12
(9,554 Views)
It looks like a Tek scope, so I think there's a button to save a screen shot; my guess is that function is duplicated programmatically.
Bill
CLD
(Mid-Level minion.)
Message 6 of 12
(9,541 Views)
hello
I have a tektronix TDS 3052 and I manage to acquire on graphs
available on labview , but instead of the chart I would like the image of my oscilloscope
Message 7 of 12
(9,489 Views)
@allbig wrote:
hello
Why don't you go look at the manual and see?  I'm pretty sure there's a command for that.
Bill
CLD
(Mid-Level minion.)
Message 8 of 12
(9,485 Views)
Did you look at the VISA Commands I used in the thread I linked to?
Message 9 of 12
(9,470 Views)
I stripped out some of my private stuff from the library I showed in the other thread.  I have not tested this exact code with the oscilloscope, so you may need to do some debugging.
Message 10 of 12
(9,463 Views)
