Object Oriented Implementation Question
So I've inherited a project that uses objects.  And I want to improve upon the design by introducing asynchronous loops.  But before I go about messing with this too much to implement, I was curious if objects work anything like Data Value References and FGVs.  If I update the object in any of the asynchronously running VIs, is it updated everywhere or only in that instance?
(2,609 Views)
The object itself is just an object, like a DBL or I32. However, an object can be implemented so that all of the data contained in the object is by reference (with a DVR, for example). So the answer to your question is maybe, but it depends on how the original developer set them up.
(2,582 Views)
LVOOP is By-Value.  You can use a DVR (of the class) to make it By-Reference, but this is generally not recommended.  I think there is an article floating around about this.  I'd have to do some digging to see if I can find it.
(2,576 Views)
So the photo I'm showing is a simple "right-click create class" object.  So what do I do to this class so that it updates in all instances?
(2,568 Views)
No, objects are, by default, by-value. You can make them by-ref by using DVR's, single-element queues, etc. There's also the GOOP toolkit that automates some of that but I've never used it myself.
(2,540 Views)
You pass around the DVR reference and use the In Place Element Structure to access the object.  The IPES will act as a mutex to keep multiple places from trying to access it at the same time.
(2,519 Views)
Turn this off, then you can put the class in a DVR.
I personally avoid DVRs (anything not by wire actually) at almost all costs.
They are hell to debug.
(2,456 Views)
