Object loses focus because of the property blink in labview 14
Numeric 1 loses focus when blink property of numeric 2 turns to TRUE, I need numeric 1 to be focused for changing numbers with keyboard.
(4,224 Views)
Yes happens also in 2015 but DOES NOT happen in 2013
Report as a bug here
Service Request Manager
Omar
(4,200 Views)
I filed CAR #540680, "Key Focus is Lost if a Front Panel Object Begins Blinking"
As a workaround you can potentially use the Key Focus proprety to manually assign the key focus back to the control.
(4,134 Views)
Dredging up a post from the past. This looks like it is still an issue. I can't find the CAR number on the internet.
Does anyone have any more info on it or shall I raise another bug?
(1,376 Views)
For anyone else who finds this, I have submitted another bug for this. Apparently it is still active but not being tabled for fix in favour of higher impact issues (The fact that this is the only thread I can find with people complaining of this issue makes me suspect that that is the right call)
(1,358 Views)
