Object reference not set to an instance of an object
I am trying to read the temperatures of a bluetooth sensor. I got my VIs from LabVIEW Bluetooth Low Energy Driver development using Universal Windows Platform (UWP) - NI Communit... It already worked however recently I keep getting the mentioned "error" (actually it is the output of the request_connect.vi. I suspect that the error originates in the initialize.vi. Inside the initialize.vi the only "parameter" is the Ble_lib.dll file. Is there any way to showcase what object can not be found and where it should be? Other suggestions on how to fix the problem are obiously welcome as well.
(1,349 Views)
The zip is empty...
(1,280 Views)
wiebe@CARYA wrote:
The zip is empty...
Zip reference not set to instance of file
(1,253 Views)
