Object requires access to data of all objects
I've got an array of objects that I typically deal with one at a time.
However there are isntances where in order to perform an action on an object, I need the data of all objects.
Following is how I am currently having to do this. Is this the best way?
(3,190 Views)
Why don't you pass the index instead of individual components?
(3,173 Views)
I suspect your design or abstraction can be better.
Can you share some more details like what is the operation your method is doing on a single object which needs array of objects as an input?
Thanks.
(3,132 Views)
This is an array of objects of axes on a PXI chassis. If I update a limit switch status on one axis, the PXI chassis needs the information from all of the axes in order to update the switches.
(3,093 Views)
The way I've been trying this is each Axis has a reference to an SEQ holding a Chassis object.
When the axis does something that needs the chassis to update, it fires a user event with the relevant Chassis object as the data.
(3,079 Views)
