Obtaining Frequency data from Agilent Analyzer
The reading part is from the AGPNA Read Data.vi
Ben64
Message 21 of 29
(1,919 Views)
So you are saying after my ReadData vi that reads the Y data, put the real 32 part of the code after that for reading the X values?
Message 22 of 29
(1,912 Views)
When changing the 1024 to 3204 I get the same error and data output.  Not sure what the problem is.
Message 23 of 29
(1,910 Views)
Is there a way to just output an S2P file that will have all this information natively.  That would be beyond Ideal for the circumstances
Message 24 of 29
(1,905 Views)
Have you tried the vi I posted in message 18?
Ben64
Message 25 of 29
(1,900 Views)
Using the Read Data gives me the Y value gain from the analyzer but no X value or frequency data.
Message 26 of 29
(1,895 Views)
I'm not talking about Read Data .vi. I said the vi from the snippet I posted in message 20. (a snippet is an image that you can drop in an empty block diagram to recreate the vi).
I would also be helpful is you posted the string displayed in Capture3.png of message 16. Do not post a picture of the result string, post it in a format that we can play around with.
Ben64
Message 27 of 29
(1,891 Views)
Ok well I can try and add all those blocks to the diagram. I am not sure exactly how to use the snippet I guess.
Also I cant copy that data.  It wont allow it to copy the data anywhere.
Message 28 of 29
(1,876 Views)
From Use VI Snippet to Store and Share Reusable Code Sections (http://www.ni.com/tutorial/9330/en/)
"Generally dragging and dropping an image file onto your block diagram will add an image decoration to your block diagram.  VI Snippets are special PNG images that have LabVIEW code in addition to the regular image data.  When you drop a VI Snippet onto the block diagram you get the depicted code added to your VI."
This should work out if the snippet was posted with a version of LabVIEW the same or older than the version you are running.
Best,
Sam R.
Message 29 of 29
(1,849 Views)
