09-28-2005 06:02 PM
09-29-2005 10:39 AM
09-29-2005 11:08 AM
09-29-2005 01:13 PM - edited 09-29-2005 01:13 PM
Message Edited by Ben on 09-29-2005 01:13 PM
09-29-2005 03:18 PM
09-29-2005 03:33 PM
How about trying to do a text search in the VI. Go to Edit>>Find. Select the Text radio button. Then type in "<control name>": <event>
For example if you have a boolean called Blah and you want to find out if there is a Mouse Up event, then you'd search for "Blah": Mouse Up
I think this would be easier than scrolling and looking through each event structure even though you manually have to type it in.
Hope this helps.
Jack J.
09-29-2005 03:38 PM
10-02-2005 08:34 AM
10-03-2005 10:15 AM
10-04-2005 01:51 PM
See online help, event structures, caveats and recommendations, Avoid Placing Two Event Structures in One Loop.
There's quite a bit of information there, starting with:
National Instruments recommends that you place only one Event structure in a loop. When an event occurs in this configuration, the Event structure handles the event, the loop iterates, and the Event structure waits for the next event to occur. If you place two Event structures in a single loop, the loop cannot iterate until both Event structures handle an event.
Roy
