Obtaining control value with web browser
Is it possible to set up a labview server vi with an activex control and
access the value of this control through a web browser such as
internet explorer.
Initially to prove the concept just on the same pc but eventually a
similar thing is to be set up over the net. ie basic moitoring of data
withn a vi remotely over the net.
Advice or a pointer in the right direction would be great.
Thanks Diarm
(2,996 Views)
> internet explorer.
> Thanks Diarm
I would suggest that you should probably pass information in and out of the
VI via a code interface node. Then get the information from the code that
the node accesses with some sort of web page (activex, java what have you).
A. B. Croll
Nortel Networks
(2,996 Views)
