Obtaining equations with 3D graph
Hi altenbach. Yep that's kinda what I have in mind but I need to be able to "predict" polynomial constants in the reflectivity range (ie you have it from 1-5 and say I want to find out about 2).
I'm still not too sure if I should use surface or parametric graph. I'm trying to understand how surface graph inputs work still (mainly the z matrix). :S
Message 11 of 40
(2,384 Views)
Are your x and y scattered randomly or do they form some kind of regular grid ? Are they sorted in some way?
As Ben said, some real data would be useful 🙂
Message 12 of 40
(2,379 Views)
Hi here's a sample that should give you an idea.
It's only 1 reflectivity, so just imagine you have 9 different sets.
Message 13 of 40
(2,376 Views)
Here's a better example.
Message 14 of 40
(2,372 Views)
Your attachment seems to be broken 😞
OK, the* .xls is good. I'll have to do some other stuff first, but that should be easy. I think I've done it before.
Message Edited by altenbach on 06-10-2005 02:26 PM
Message 15 of 40
(2,372 Views)
Is there an ActiveX object for an Excel pivot table that could be used inside labview?? Setup a pivot table in excel where the page data selects the reflectivity.
Message 16 of 40
(2,360 Views)
Here is a link to Office XP web components activeX. I think what you would want to use is a pivot chart.
Message 17 of 40
(2,358 Views)
Sorry I forgot to mention. The user probably won't save data until the very last point. So I need to do everything inside Labivew (ie passing values by table & arrays).
Typical operation for a user:
1. Setup apparatus
2. Input variables and start Read Grid.vi
3. Read Grid.vi is finish
4. Analyze data #1 - find out polynomial constants for the 9 reflectivity backings used & save them in a txt file for later use.
5. Predict polynomial constant for a specific reflectivity value within the 2%-99% range (3D graph, still need to be implemented) & save them in a txt file for later use.
6. Save table values to a txt file.
Message 18 of 40
(2,356 Views)
Take a look at the 6.1 llb.
I took advantage of your data to play around with various 3-d plotting schemes.
The example builds on Chistians example but uses the data you provided.
I had to do a lot of guessing on how the data should look.
i think a 6th order mapping works out quit well.
Have fun,
Ben
Message 19 of 40
(2,337 Views)
Sorry for the late reply. Thanx Ben for the file but I don't quite understand what you did. When I clicked on the file there are 6 different VI's. After playing around I think you use the 3dGraphTestMod.vi right?
The program is kinda what I want but for select reflectivity I need to be able to predict values. (Ie there are data for 2%, 25%, 50%, 75%, 99% but I want to be able to type say 35% and the program will find the polynomial constants for me).
Message 20 of 40
(2,330 Views)
