Obtaining readings from Keithley 2000 DMM
I have a Keithley 2000 DMM with RS-232 communication, a PC running LV 7.1. I have established communctions between the two using RS-232 and I am able to do *IDN? to generate a query of the instrument. However, I would like to read in the readings (DC voltage) from the meter at a button press. What command string would I send to the unit to get this data? Any help is greatly appreciated!
Thanks!
Mike
(2,739 Views)
You should get a programming manual from Keithley just so you understand what's going on but you should also download the driver.
(2,726 Views)
Either read the manual on the instrument or download the drivers from
Keithley 2000 Drivers
(2,723 Views)
