Obtaining the state of a switch
I've got 3 nested loops: While-Case-While
If the user hits a front button, the case statement returns true and the inner while loop gets executed.
Now, what should I do to exit the inner while loop in case the user hits the same button again?
In other words, can I somehow "check" the same button in different loops?
Programm is attached, the loop in question is the very first one on the left!
Cheers,
Georg
(2,581 Views)
Im not sure I completely understand your question and I cannot load your VI without the sub VI however you could always use a property node to monitor the value of the button or a local variable to pass the value of that button within that VI. (or if need be a global if it is between different VIs)
Hope this helps.
Dave
(2,581 Views)
Well, the program uses a serial communication, so it wouldn't work even with the Subvi.
Anyway, will a pressing of the button be noticed by the program if I use a property node, even if the actual execution of the vi takes place in another part of the while loop?
(2,581 Views)
The pressing of the button will be noticed by the "value" of the property node as long as it is in the same loop. For instance I have a VI I just finished to control a laser and while I use event structures I have property nodes outside that structure but within the same while loop. They just cant be in a different loop or they wont be recognized since that loop is not being handled at that time.
(2,581 Views)
Thanks for your answer, So will the pressing be noticed, even if another while loop within the while loop is being executed? No I reckon.
(2,581 Views)
