Obtaining variable values from string
So I have a shared variable string that sends something that looks like this:
"a = 1.0000E1
b= 2.0000E4 "
And so on. What function should I use to extract the number from a, so that I could read 1.0000E1?
Message 1 of 15
(5,694 Views)
You could use "scan from string" and set the initial scan location at 3. If the string before the "=" can be longer, find its position and scan after it.
Message 2 of 15
(5,675 Views)
If the input string is multiline, something like this will give you an array of variables and an array of values.
aputman
Message 3 of 15
(5,668 Views)
That is very close to what I am looking for!  What if my variables aren't just a-z, but long complicated names?  In the actual application, I have over 50, but I want to extract 5 of them, so could I just do %[var1,var2,var3,var4,var5] = %e in the search
Message 4 of 15
(5,649 Views)
That returns a string that contains those characters.  If you want uppercase and/or digits, use "%[0-9a-zA-Z] = %e" as the format string.
aputman
Message 5 of 15
(5,644 Views)
Using the same front-end as aputman, you may need to search on the '=' sign if variable names change in size and content.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
Message 6 of 15
(5,640 Views)
So I am attaching what I have so far.  Say out of the variables, I want to only read a,c and variable_one.  And this is always known, but the values way change.  Can I have it so that it does that?  ie "[a,c,variable_one] = %e" ?
Message 7 of 15
(5,619 Views)
Use %s = %e
Ben64
Message 8 of 15
(5,597 Views)
You will need to split string on '=' if the string in the opening thread is correct.  The variable name a is followed by a space where the next line with b has no space before the equal sign.
Message 9 of 15
(5,589 Views)
@ben64 wrote:
Use %s = %e
As long as there is a space between the name and the =, that will work.  If not, then use %[^=]=%e.  Personally, I would probably use the Match Pattern to find the = and then convert the After String (value) and keep the Before String (name).
Message 10 of 15
(5,584 Views)
