phi wrote:
> What I'm seeing is the occurrence can be set in the DLL or the test
> VI. The occurrence can be checked in the DLL or the test VI, however,
> the occurrence will not clear in the other (i.e., if the occurrence is
> checked in the DLL and found to be set, then checked in the test VI,
> the occurrence is still set).
> Has anyone else experienced this? It seems that checking the
> occurrence in either should clear the occurrence in both, especially
> as it can be set in either.
I think you expect a different behaviour of occurrences than what is
implemented. If you have two places waiting on the same occurrence
refnum they are supposed to be triggered both when that occurrence is
set and depending on "ignore if previously" set even if the Set
occu
rrences has occurred before the Wait Occurrence executes.
Rolf Kalbermatter
Rolf Kalbermatter
My Blog
