Ocean Optics OceanHDX spectrometer driver.
Hi a.texer,
Great, thanks for solving the issue!!!
But: I don't know how to add the .NETwrapper node on my block diagram... Adding InvokeNode from the .NET palette is labeled .NET only , and when linked to the OceanOptics reference, changes to OceanOptics.
Where to you get the .NETWrapper element from, which palette??
Best,
Jorro
Message 21 of 23
(905 Views)
Make sure that correct OmniDriver is installed:
https://www.oceaninsight.com/support/software-downloads/omnidriver-and-spam/
.NETwrapper node can be copied/pasted from the VIs in the archive or created from scratch using .NET invoke node.
See below.
VIs are also attached.
Message 22 of 23
(892 Views)
I found something might be solving this problem.
After closeDevice method, the shutDown method should be also called. Since then I do not suffer the crash anymore. It was very reproducible on my system, LV18 64bit, OceanDirect 2.4.0, SR4 spectrometer.
Message 23 of 23
(461 Views)
