Ocean Optics USB4000 Spectrometer
I specifically ask for the error message becauseit sometimes happens that the usb bus power is removed.
You have to check all powersettings.
It is a real windows feature.
greetings from the Netherlands
Message 231 of 286
(2,129 Views)
Hi
I uploaded the error for your reference
Thanks for your reply
Message 232 of 286
(2,096 Views)
Hi
This seems to be a timeout problem.
Do you sometimes get real spectra or is it always a problem.
Message 233 of 286
(2,084 Views)
Hi, I know this is an old thread but it seems this is the right place to ask question about Ocean Optics Spectrometer. We have several OO spectrometers, all externally triggered. The external trigger often changes its pulse trigger rate, and when it does, OO spectrometer gives me an error message, "Instrument not synchronized properly. Power cycle instrument". Our system will be all automated and will not easily be accessible to power cycle the instrument. Is there a software command to power cycle/reset the instrument? I couldn't find the command from neither their manual nor LabVIEW driver.
Thanks in advance.
Message 234 of 286
(1,945 Views)
Depending on the driver version, this could also be an incorrect errormessage.
Before maybe 2013 the error sequence at the end of read data was wrong and you can test this by wiring an empty visa resource to th init.
If that vi returns the powercycling error it is an old driver.
I renewed this but be careful, I also changed more making it necessary to recalibrate the x-axis.
Good luck
Message 235 of 286
(1,925 Views)
Hello Albert,
Thanks for the reply. The init gives a standard visa error if empty resource name is passed in. I guess I must have the newer driver. So, the error message must be valid. It being said, is there a command to reset the spectrometer to fix this error message? Or hard power cycling (unplug) is the only way.
Thanks!
Message 236 of 286
(1,906 Views)
Hi Tgif,
the alternative would be using the proper instrument driver. The OmniDriver does not care about the external sync rate and if i am honest, i have not seen a need to power cycle the instrument with OmniDriver in the past 5 years. The "NI driver" bypasses our interfaces and talks to the communications chip directly. Feel free to touch base directly with me (oliverl@oceanoptics.eu) if there are questions concerning the OmniDriver.
Message 237 of 286
(1,886 Views)
I neither have seen a real need for powercycling.
The only time it looked like that was when windows decided to powerdown the usb bus to the ocean optics instrument.
Message 238 of 286
(1,853 Views)
I am having driver troubles with my HR2000+ using the NI-VISA USB drivers.  I'm at the end of my rope.
I have searched high and low for answers and implemented everything relevent.  For example, I know the difference between the OO drivers that come with OceanView, and the signed LABVIEW drivers that are available for download from NI.  I can install either one with ease.  However, when i use the hr2000+_vista.inf, I still cannot get my device to show up in NI-Max.  The most frustrating part is that I had this working almost a year ago and developed software around it, which is now useless.
Any suggestions on how I can completely wipe all driver information and 'start over' so that when i plug in the hr2000+ I can install the NI _vista.inf (assuming that theres some kind of driver issue..)  Thanks in advance guys.
Message 239 of 286
(1,687 Views)
Can you try to make your own INF file instead of the ones you have there?  Or did you already do that?
See this guide:
http://www.ni.com/tutorial/4478/en/
Message 240 of 286
(1,665 Views)
