Octave Analysis Express VI
I've been working with some old code where the previous programmer used an octave analysis express VI. Using context help I'm able to see some of the settings used, but when I try to replicate the analysis using the SVT Fractional-octave Analysis VI from the sound and vibration toolkit I'm not getting the same results. I've tried to find documentation about the Octave Analysis Express VI without success. I simply want to find out what the express VI is doing. If anyone can point me to some documentation or if you know some details about the express VI it would be appreciated.
(1,497 Views)
I don't have the toolkit in question to see if this would work, but with Express VIs in general you can see what they do if you right-click them on the block diagram and select "Open Front Panel".  You'll get a warning message saying that if you do this you can't configure it as an Express VI any more, but once you click OK you can then see the VI that actually runs when the Express VI is called during normal runtime.
Assuming it's not password-protected or just calling a DLL, you should be able to get more information that way.
(1,489 Views)
