Octoplus USB 3.0 not shown on NI MAX
I am trying to connect to Teledyne E2V Octoplus USB 3.0 line scan camera with LabVIEW but I don't see the camera on NI-MAX. I've seen example of using LabVIEW and Octoplus camera with cameralink but not directly connecting with USB.
I see the camera under USB from device manager and works well using E2V software.
Has anyone used this camera (USB3) with LabVIEW?
Appreciate any help/feedback.
Best.
(1,236 Views)
Does Teledyne provide an IMAQdx-compatible driver?  Do they mention "LabVIEW Vision" compatibility?  The presence of a driver compatible with vendor-supplied software does not imply that they will be compatible with LabVIEW.  I suspect this may be the case with your camera.
Bob Schor
(1,191 Views)
Maybe you've solved this problem by now.  However, Teledyne offers a C++ DLL "CamCmosOctUsb3.dll" for their Octoplus USB 3.0 camera.  Since LabVIEW cannot directly call C++ DLLs, you will need to write a C wrapper DLL for the functions you will need and then write LabVIEW wrappers around each of those functions.  This has been done before so I know it works.
(571 Views)
