Oen third party appliaction
currently í´m making VI, that should open another appliaction which is not a VI.
I manage to do this by using System exec vi.
Application opens and then ask to enter password.
How i can enter a pasword automaticaly from labview program? Also i need to simulate pressing OK button...
Thank you
(2,897 Views)
Hi milan,
use AutoIt. Or try to fiddle with Windows API function calls to manipulate windows of other applications…
(2,883 Views)
Thanks for a fast answer...
How i can implement this code... It write hello as it should be, but i cannot to connect with field i want to type...
Can you advise?
Thanks.
Best regards.
(2,864 Views)
You need to activate that field somehow. Most applications support TAB. Try manually first too see what key-presses you need.
Certified LabVIEW Architect
(2,805 Views)
Oh, and you may want/need to activate that application window too:
https://forums.ni.com/t5/LabVIEW/Bring-Window-Forward-Executable/m-p/3923832/highlight/true#M1114785
(2,800 Views)
