Offset binary to 2's complement
Hello.
How can I convert 12-bit offset binary word to 12-bit 2's complement word? Thanks.
(3,276 Views)
Hi Valentin,
What is a "12-bit offset binary word"?
What is a "12-bit 2's complement word"?
When it comes to LabVIEW datatypes a "word" typically is a 16-bit entity, like U16/I16. So you need to explain your input datatype and the expected result more clearly before we can help you…
(3,270 Views)
For example, I have dec value = 3754 (U16). I must  get value in I16 in 2's complement code.
(3,263 Views)
Lots of options, but this does the trick:
If the intention is to convert to double (the 'resolution' of 0.0625 is just an example):
(3,246 Views)
