Hello everyone,
I am using Labview 8.0 and a PCI 6221 card.
I have got an offset pb with my AI channels. In order to avoid a software pb I am using the Assistant DAQ to check the voltages. All my AI work fine when I measure 0.150 V generated by a power supply. However when I measure the voltage of the signal coming out of my circuit (what a realy want to measure in the future), which is roughly 0.150 V, the mesaurement is correct only when the signal is set as first in the list in the daq assistant. If my signal is connected to channel 1 for instance, the measure will only be correct if I choose the order the order 1, 0,2 or 1,2,0. If Channel 1 isn't put in first place I get a 30 to 60 mV offset on this channel. This doesn't happen at all if I use a power supply with the same voltage, and in any order channel.
Would anybody know how I could solve this pb?
Thanks a lot,
regards,
Marc
