Oh crap, I should have made a typedef for that...
Is there a way to link a control to a typedef?  The typedef is the exact same as the control, and I do not want to delete the control and place a typedef custom control in its place.
(2,788 Views)
Hi Nickerbocker,
use "Replace" from the context menu of the control...
(2,783 Views)
If Replace is not good because you would loose the control appearance, then check this:
http://forums.ni.com/ni/board/message?board.id=170&message.id=396036#M396036
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(2,779 Views)
Replace worked great!  Thanks!
(2,773 Views)
