Old VIs in LabView 2010?
Hello
i have some old VIs to integrate an HBM Spider8. The VIs should work up to Labview 7.x but i use 2010.
Is there any possibility to upgrade the VIs or just to look how they work and what they do?
Thanx
Sebastian
(2,357 Views)
If you have older versions of VIs that won't upgrade to LV2010, you can post them to the upconvert thread.  If they are in Lv7.x, they should upgrade on their own.
(2,345 Views)
