It is a huge project wherein some decisions need to be taken based on the result of a particular test [Pass/Fail]. If it fails, it ll be put into Bin5. Likewise many other tests may also be assigned to Bin5 on Fail. So, whenever Bin5 gets incremented, some other processes, as I said earlier, must not be carried out. So, I need to check this BIn5's value in every test execution cycle.
I think we ve got only 2 methods to code for this. Either use a dummy variable to keep Bin5's previous value or use the ES to get its previous value. Then, we can do the comparison with its current value & if there is a difference. I ll avoid doing those processes.
It is a huge VI, wherein all the processes are carried out in the main Producer while loop and the menu pop-ups for datalog & report viewing are done by the consumer while loop. No ES is beibg used as of now.
Does this shed more light on the need ?
Please clarify me about some other methods.
- Partha ( CLD until Oct 2027 🙂 )
