Old version of Labview: Adding a frame to sequence
I need to add a frame to a sequence in an old (Labview 3.0 for a Mac) version of Labview. I have no documentation for this version of labview. There is no sort of border pop-up menu with an "add frame after" feature.
Any help is appreciated.
Jim
(2,744 Views)
> after" feature.
The border popup is definitely how it is done. It should have an Add
Before and a Add after. These may be obvious, but make sure that you
are using the Command-Click to get the menu, and also check to see if
the VI is locked. Unlock it using VI Info by popping up on the VI icon.
Greg McKaskle
(2,744 Views)
