OleAuto32.dll crash after start of exe
i've developed 2 software which read/write informations on a same activeX. This activeX use window memory map file to allow exchange informations between both software.
Both programs runs perfectly when there are started from the labview environnement.
When i start the software from the executable file, following error appear : Access violation by oleauto32.dll
Someone could tell me what's happen ?. Why both software runs when there are started from labview, and why there generate an error only when i start the executable ?
thanks
woully
(2,807 Views)
thanks
woully
Hi woully,
i need more informations,
do you run the executables on the same PC as the vi´s ?
What happens if you start only one executable?
Benjamin
(2,791 Views)
