Omega DAQ-3005 VI error
I am trying to run the LabVIEW example VIs that came with my Omega DAQ-3005 USB device. I can operate the device just fine using the DaqView software that Omega supplied so I know that the hardware, etc is installed properly and working. When I use their VI titled "DaqBoard USB 3005 Analog Input and Thermocouple Example.vi" I get error code 2147467262 "Variant To Data in DaqUSB Analog Input Config.vi". I have contacted their customer service but I have to wait for them to return my emails and Id like to get this thing running ASAP. THanks
(3,466 Views)
If you could post the appropriate vi's to this thread it would help. This includes any sub-vi's that the main vi requires. Ideally zip them all into one file, and include what version of LabVIEW you are using.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,464 Views)
Thanks LV_Pro. I zipped the entire LabVIEW support folder. The vi I am using is in Howto and Example VI's\Daq Device Examples\DaqBoard 3000 USB Series\DaqBoard USB 3005 Examples\DaqBoard USB 3005 Analog Input and Thermocouple Example.vi. I am using LabVIEW 8.2 but got the same error on a 2nd machine using LabVIEW 7.1. THanks again.
(3,463 Views)
I guess I tried to attach to big a file.... Anyway I think I have things figured out (a good night's sleep always makes things clearer in the AM). Thanks anyway !
(3,442 Views)
