On KEY down the key navigation toggles a control continuously. I need a way around this.
I need to be able to press down on the F1 function key and have it "switch when released" only. I have to provide two capabilities; use the function keys or the mouse to toggle a boolean. I used key navigation but using key navigation toggles a boolean on a continuous  basis if the user keeps the key depressed. This is not the behaviour I am looking for and it seems I can't control this functionality in the key navigation setup screen. Therefore, I need your help.  Any ideas?
Check the attached vi. It's shows an example of the key navigation behaviour. Run it and press down and hold the F1 key.
Wil
(3,305 Views)
I forgot to mention that I am using LV 8.0
For those of you with other versions here is a picture of the diagram.
(3,302 Views)
What you are getting with the keyboard is a series of new key-presses.  If you press and hold a letter key like "a", you get lots of letter "a"s.  The same thing is happening here.  So, it is not read as a holding the key down.
Maybe you will have to use something from the Connectivity -> Input Device Control palette.  I have not use them, however so I won't be much help.
Hope that this helps,
Bob Young
(3,287 Views)
Assuming that you have more than the base version of LabVIEW, you can use the event structure. Use the This VI>Key Up and read the scan code. F1 is also the Help key so you might want to try it with another F key. The event structure should also be used with a Value Change event on the Boolean control.
(3,279 Views)
Bob
The Connectivity -->  Input Device Control Pallete has tools that might help me with my problem. I tested it and I find only one problem so far and that is that pressing F1 calls and opens the LabVIEW Help program. This is normally disable with key navigation because I have selected to "override system default function key settings" in the Tools-->Options-->Front Panel.
Does anybody know how to disable this short cut for LabVIEW Help?
Wil
(3,270 Views)
I am going to post this F1 issue separate under the title "How to disable Function Key".
If I can disable the function keys then I will have a workaround for my initial problem with the key navigation.
Thank you for your help, all that replied.
Wil
(3,257 Views)
