‎07-29-2003 08:08 PM
‎07-30-2003 06:56 AM
‎07-30-2003
08:38 AM
- last edited on
‎09-02-2026
08:34 AM
by
Content Cleaner
You must start the OS to run any LabVIEW program because it needs it to use the services the OS has like File I/O, windows ....
What you want is a system here only you LV app is available to the user. This can be reached in some different ways depending on your needs.
1. Add your app to the autostart group of the machine or the user.
2. Make an entry in the registry under HKLM\Software\Microsoft\Windows\Current Version\Run to start during boot or HKCU\Software\Microsoft\Windows\Current Version\Run to start after login.
3. You can make your app as the shell. The shell that will be started is in the registry under HKLM\Software\Microsoft\Windows NT\Current Version\Winlogon. It is the value shell you have to change. For test be sure to have a button to r
each regedit to change this setting backwards. Also you need to add a mechanism to logoff the user or shutdown windows from your app.
Waldemar
‎08-01-2003 02:36 AM
