Onboard_motion_trigger.vi switching to axis 2 help
Hello Everyone,
There is a program Onboard_Trigger_Motion.vi code that I found in the forums.  Unfortunately I want to run axis 2 off of a UMI 7764 controller, when I switch the vi commands to axis two and then run it, the program automatically switches the settings back while running to axis one.  So I suppose my question is how do I run axis two off of this program.
The example can be found at this link.
Thank you in advance for your time.
-Keith
(2,674 Views)
Bump
(2,666 Views)
Hello Keith,
Try opening the VI and selecting Axis 2.  Then click Operate>>Make Current Values Default.  Then save the VI and run it.  If this does not work, try changing the Axis control into a constant of Axis 2.
Allen H.
(2,650 Views)
