Once running the labview program which contain DAQ Assistant ,the message of "ERROR-50405....." appear.
Once running the labview program which contain DAQ Assistant and can be run without any error before, the message box of "ERROR-50405....." appear which capture down in the attachment. We use PCI6221 and LabVIEW 8.0 in Windows XP. I also found that the Device Manager of Window have recognized the PCI6221.
Any help on this situation would be great.
(2,763 Views)
Hi~
This error is due to signal interference between the device and the computer. This could be environmental or due to the PCI Controller. You can on a different computer to see whether this problem persists.
(2,735 Views)
