Once true, make LED stay green
I have an LED that lights green when a timer and set time are equal/greater than.  How can I force the LED to stay active?  Such as if the timer gets reset...  The LED needs to still show active.
Message 1 of 13
(4,955 Views)
You can use Boolean's Property Node > Value to set the boolean to high.
Andy Chang
Message 2 of 13
(4,950 Views)
Use a feedback node. Wire the OR of current value and last value to the LED and back into the feedback node.
Message 3 of 13
(4,948 Views)
My only problem with that is that it's all constantly being looped.  Won't it just keep checking?  If the timer gets reset it won't match the set time then the boolean will just reset.  Attached is the code for what I have.
Message 4 of 13
(4,932 Views)
Or search the forums for a Boolean Latch. Such as the one in this thread.
Richard
Message 5 of 13
(4,927 Views)
In case you don't know the feedback node, here's the concept of latching using a shift register.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 6 of 13
(4,921 Views)
I guess I should have thought of that... Smiley Very Happy
Message Edited by NIquist on 03-19-2010 04:15 PM
Message 7 of 13
(4,908 Views)
Message 8 of 13
(4,894 Views)
hello everyone,
i hope that i am posting under the right header.
I did a program for led using case structure and while loop. but the problem is that the led is blinking. i
dont want it to blink. i want the pin to stay high then when i press the boolean, it shall be off.
the led pin is on my breadboard.
can any1 help
 the first snapshot i use a simple case structure
Message 9 of 13
(4,203 Views)
@Zahkay wrote:
hello everyone,
can any1 help
Start a new thread.  And post the actual code.  The pictures you gave is not enough information to diagnose the issue.
Message 10 of 13
(4,190 Views)
