One TCP Write to send both Length & Data?
Thanks,  always wondered where that thing was hiding.
Successfully Edited
Message Edited by SiegeX on 11-17-2008 05:01 PM
Message 11 of 14
(848 Views)
One thing I thought i'd mention on why you may want to use 'Flatten to String' over typecasting is that the typecast primitive does not seem to accept a cluster whereas the 'Flatten To String' primitive does (and anything else you throw at it.)
Message 12 of 14
(838 Views)
SiegeX wrote:
... is that the typecast primitive does not seem to accept a cluster
Actually, typecast accepts certain clusters just fine (either as data input or type input) as long as the cluster does not contain arrays or strings, for example.
If you have a cluster that has a fixed data size, it's OK. (e.g. try a cluster of booleans and numerics)
Message 13 of 14
(835 Views)
Ahh, good to know, I was throwing in a cluster of arrays as you might guess.
Message 14 of 14
(824 Views)
