One Wire Interface
I need to use the Maxim ID chipe DS2401. I want to use the one of the DIO lines from the NI DAQ usb 6255 to communicate with this chip. Do anyone has an idea how to write the protocol to read from this chip?
(2,807 Views)
Hi MansoorEE
I think you should try to look for the protocol with the manufacturer. I guees you did that, too but it is harder to find someone with that knowledge in LabVIEW forums,
Regards!
(2,756 Views)
