One analog output reserves all output channels
I am trying to use multiple analog outputs to send output squares waves of different properties (frequency, duty cycle, initial delay, etc...). I have attached a vi that produces simple triggers. While this vi is running, I can't generate a continuous sine wave on one of the other analog outputs using Measurement and Automation Explorer.  I know it has something to do with the fact that is only one hardware sample clock available. I am using M-series 6259. Is there a workaround for this?
(2,726 Views)
Are you trying to create different tasks for each output channel?  You need to have all of your analog outputs in the same DAQmx task.
(2,716 Views)
Yes, I have multiple tasks because I need to start/stop those tasks at different times, depending on the stimulus requirement.
(2,702 Views)
You can only do this if you run one task at a time. You simply cannot have more than one task running at once. So, make sure you stop each task before starting a new one or combine all channels into one task.
(2,693 Views)
