One axis from ADXL345
HelIo,
I have successfully connected one adxl345 to my Arduino using labview and linx and I2C protocol. I want to achieve bigger sampling rate, so after changing the baud rate(115200) i tried to get only the y axis data by changing the adxl345read.vi as you can see in my attached vi. Unfortunately I didnt managed to get an higher sampling rate. Is this Logical or am I mistaken?
Below I attach not only my VI, but also a screenshot with adxl345read.vi which I changed.
(2,448 Views)
Hey ADXl345,
LINX questions are better handled by the forums I linked below. Digilent is home of LabVIEW Makerhub and they created the LINX toolkit. Goodluck!
Digilent - LabVIEW Forum
https://forum.digilentinc.com/forum/9-labview/
LabVIEW Makerhub Forum - LINX
https://www.labviewmakerhub.com/forums/viewforum.php?f=12
-Austin
(2,400 Views)
