One graph palette for two/several plots
Hey,
I've the same problem that "5" (zoom to fit) is not detected.
Did you found a solution or workaround on this problem?
Greetings.
Message 11 of 14
(753 Views)
Hey,
Unfortunately, I did not find a workaround for this problem.
But it is nice to see that I am not the only one who has this problem.
Perhaps your question brings this topic back into use and we get help from other people here. I still would be interested in a workaround too.
Message 12 of 14
(744 Views)
Maybe you could try something like this. (Unfortunatelly I can not upload the vi??????? )
But it will detect every state where your data are fully shown in the graph.
However, I think this would be ok for me and I could live with that.
some other ideas?
Greetings.
Message 13 of 14
(737 Views)
This is a nice idea (which I also had). And if it works for you, then you can be happy.
I was not satisfied with this because I really want that the user can use the bottom “5” (zoom to fit). But my problem is slightly different to your problem, because I have two plots. If apply your solution, the user can’t use the bottom “5” for at least one plot.
Unfortunately, I do not have any other idea for this so far.
But as said, if you are happy with that, you should keep your solution.
I decided to use a graph palette for each of my plots, this solves my problem too 😉
Message 14 of 14
(714 Views)
